Check to make sure your brake light switch is functioning fine. After I replaced my clutch master cylinder the brake light switch was slightly off from before so the brake lights wouldnt shut off. I slightly bent the plate that the switch touches and it fixed the problem. Also make sure the brake switch and both clutch switches are hooked up and make contact when theyre supposed to.
