Well I have been dealing with a belt noise and shredding issue ever since I installed the Whipple a few months ago. I even put the car in a trailer and took it to Whipple. They can see no reason for the car to shred belts or make noise. But yet it still does. Whipple has been great to work with and they are just as frustrated as me. As a final attmept, I installed an 8 rib GI Joe kit. The belt was on less than 25 miles and I noticed that it was starting to shred. This is the first time I have been able to catch the belt before it shredded completly. It appears that it is starting on the smooth side of the belt and down into the ribs. Everything is aligned. I have replaced the tensioner and it is not bent. I loosend the intake to see if there was any fore or aft movement and there is not.
Now for the noise. Everytime I install a new belt it is perfectly quiet. No noise at all. Once I drive the car and it cools the next time I start the car it is squealing. The more drive cycles the car has the squeal is louder on cold starts and takes longer to go away. Once the car is full operating temp and has been driven for several miles the noise is gone until the car cools.
When the belt is making noise I can put a small amount of water on a paper towel and hold it to the rib side of the belt and the noise is gone until the water dries. The water has to be on the rib side holding the towel on the flat side or the sides of the belt does not make the noise go away only the rib side. I'm not talking about a lot of water either just a damp paper towel. I can also change the pitch of the noise by taking tension off the belt. When I do this I notice that the belt slides back on the tensioner idler towards the radiator and the noise stops and as I let the tesioner back down the belt rides towards the block on the tensioner idler and the noise is back. If I install the stock belt the noise is gone as well.
I also installed a 6 rib belt on the 8 rib pulleys to see if it would want to walk one way or the other and it does not but is just as noisy.
Sorry for the long post but I can't live with this any longer and don't want to remove the blower.
Any thoughts??
Thanks,
Sam
Any thoughts??
Thanks,
Sam
