DIY Lower Valance
rkaiser
Flemington, NJ 08822
In the attached PDF I documented the steps to upgrade a 2010 GT rear lower valance to a 2010 GT500. This may also apply to 05-09 years as well as other applications.<o:p></o:p>
<o:p></o:p>
Job Time: Approx. 1.5 Hrs
The process is good for the following:
<o:p></o:p>
Bumper replacement<o:p></o:p>
Valance replacement / upgrade<o:p></o:p>
Brake Light assembly removal / replacement<o:p></o:p>
The tools used:
<o:p></o:p>
1 - Phillips screw driver<o:p></o:p>
1 - Flat head screw driver<o:p></o:p>
1 - 1/4" socket wrench with a 1/4" socket and a Phillips bit<o:p></o:p>
(or you may remove the back wheels and use a Phillips head)<o:p></o:p>
Optional: <o:p></o:p>
Tool for removing plastic push pins<o:p></o:p>
1 - 3" Spackle knife / masking tape<o:p></o:p>
Drop cloth / towels / tee-shirts<o:p></o:p>
<o:p></o:p>
*Bolts and plastic push pins vary based on the type of valance you are mounting.<o:p></o:p>
<o:p></o:p>
I hope this is helpful.
  • DIY_valance.pdf
