DIY vortech Kit - Coyote
boduke0220
Whats up Guys. My buddy has a 2011 5.0 M6 with the usual bolt ons making 431rwhp. He's looking to step it up a notch and do some forced induction. I have a 2v with the DIY vortech and custom FMIC. He wants to do the same.
So heres my Questions
WHat MAF, Fuel Pump, and injectors do you guys recomend. obviously he isnt building the motor so Im guessing 60lb injectors? Car will be a blow through setup, will an HPX slot style work?
What size belt and pulley would he need for 8-10 psi? Thanks!
wazslow
The stock maf will support way more than the stock motor will handle. PM beefcake on here for a paxton or vortech kit, it will come with everything you need.
Chiron
Salt Lake City, UT
I don't see you saving much money at all by piecing a Coyote kit together. Earlier models, absolutely, but the parts are still very expensive for a 5.0.
Bracket assembly - $997
Intake assembly - $329
Coolant shit - $206
Discharge assembly - $1,274
Injectors, a fuel system, the head unit itself, a FMIC or similar, plus whatever miscellaneous shit you need will add up QUICK. Get with Beefcake, he'll set you up with everything you need at a screaming good price.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
Easy bolt on!:clap:
