driver side window motor
05 vert
my 06 gt convertible window motor is bad. i cant find a video how to change it. do i have to take the glass and regulator out. thanks
05 vert
Thanks for the reply but thats not a 06 gt. So i cant just chsnge the motor?
MrBhp
Sorry. I must have sent the wrong one. I just frign watched it. Gimme a minute.
MrBhp
Does the window motor work at all? I think you have to roll it all the way up before you start. I am fairly certain that the glass does not need to be removed. But it will fall as soon as the motor is disconnected. I usually use tape to keep it from falling.
05 vert
the motor makes noise but window wont go up. it sarts going up then goes down
JC SSP
FL
Isn’t the regulator attached to the motor?
MrBhp
The motor is running. Might be good. A fastener has possibly loosened. Have you taken the door panel off?
05 vert
yes nothing looks loose i pulled on the window while holding the up switch. i got hit halfway up. motor feels hot
