DUAL FPDM
lostsoul
2014 vett or 2015 stang..
Gay Area
that's because most 2010 owners traded their cars back to the stealerships for the 2011 5.0 :poke:
lostsoul
Gay Area
I wold have traded mine in.. but I already paid for another stang after I had liability only on the first one =-/ ... 70K aint sheet to me :(
Jared@Lethal
Are you referring to the 2010 GT 500 or the 2010 GT? I have a 2010 GT and just installed a GT 500 fuel pump this weekend with the only issue being the wiring for the fuel gauge...so I don't understand what you mean by a different fuel sender unit..?
The 2010 GT and GT500 both use a different fuel level sender than the previous 05-09 did. What will happen if you use a 05-09 level sender on your car such as the one included in FRPP GT500 fuel system # M-9407-GT05 is that your fuel level sender will not register the fuel reading correctly. It's almost like the 2010 does the opposite as the 05-09 does. If you fill the tank the level reads low. When you run low on fuel the level reads high.
There's a separate part number for 2010 cars that want to run the FRPP GT500 system which is M-9407-MSVTA. Here's the note the have on their site as well.
Note: Use of this kit in a 2005-2009 Mustang will result in an incorrect fuel gauge reading.
Hope that helps.
Jared
Greg Hazlett
Stepping on the Pink Bus
Official Vendor
Chesapeake, VA
Thanks for the info...sigh...need to find someone with a 2010 GT 500 to swap with...or just live with an opposite fuel gauge...hmmm...so....if I swap the F and the E it will be right, problem solved!:idea:
