BlackCDCStang
I recently unscrewed the top of the EGR pipe to put on a new high heat sleeve. Process was easy and right after I drove for over 3 hours no problems. Now I am having issues and this code popped up.
Basic Symptoms so far through tests...
I start car and it idles smooth, I turn the blinker, AC, Headlights or cautions on and the car dies. I can roll up and down the windows, turn on the map lights and mess with the radio and nothing happens.
I played with the blinker and revving to test more and upon revving the car over and over and then turning the blinker on and it bogs down so I rev off and on harder to keep it running but it will soon die again when I stop revving.
I can also start the car and let it idle and it will die on its own without touching anything periodically.
I took it for a drive without touching anything and I felt like it was running fine...
I went to Autozone and put a brand new battery in just to see and it did not help. I have checked all the plugs etc and nothing is lose or cut.
Any ideas on what to do? The next step is to replace the whole EGR Valve but I would hate to spend another $100 and that not be it.
Anyone else experience this issue and know how to fix it?
