01bluesnake
- Joined
- Dec 9, 2011
- Posts
- 44
- Reaction score
- 0
Well, i was able to get to the track yesterday for the first time with the car, did 3 runs and was very pleased with the results. The car has 3.31 gears and a 275/60R15 M/T radial which is a 28". I didnt want to step down to a 26" tire so i could see what a tire close to stock size would do without changing the actual rear gear calculation. They are mounted on a 15x10 for a better tire foot print. The car at the track had no spare, no front sway bar, Off road BBK cat deletes, DR tire, and a 93 tune by me. I was leaving off a 4500 sct two step for the first and last run. The first run was a wash since my tire gauge was reading about 7 psi low, and they weren't checked hot. On the second run i had them dialed at 15.5psi, but left at 3600 and bogged running a 12.4 @112. The last run i did a crappy burnout and launched at 4500 giving some spin to a 12.2@113 run with a 1.91 '60. I didn't cut my stock bump stops in the rear and think it may off caused me to unload from bottoming out. The temp out was 92* with a track temp of 125*. The DA was 3000, normally around 1000 in chicago area's which hurt the times some. My friend did the DA correction to a 11.64@119, but that would be a perfect cool air night and may be a little generous time. I'm trying to get to the track again on a cooler day with the stops cut, but for now here's some pics and a vid.
Track stats:
92* outside temp
125* track temp
DA 3000
Best run:
[email protected]
'60 1.91 spinning
1/8th was 7.918 @ 90.24
Video of last run
http://www.youtube.com/watch?v=1XaaLkDUAV8&feature=youtu.be
Smoked the tires up first run due to incorrect tire pressure
Track stats:
92* outside temp
125* track temp
DA 3000
Best run:
[email protected]
'60 1.91 spinning
Video of last run
