I do not see the float or sending unit or sending unit bracket???? Complete??
Just a heads up so nobody is pissed later...
ONLY the 07 up GT500 brackets for the sending units will work on this.
If using a GT500 sending unit then only the 07-09 GT500 sending unit will work if from GT500. Later model GT500 sending units will not work.
Early 05-06 GT (non tsb) sending units (with the metal brackets) will work on those 07 up GT500 sending unit brackets but you have to have the gt500 bracket and those are not sold individually. The 05-06 GT bracket will not work on these pumps. None of the gray plastic GT sending units or brackets will work on this pump.
Sucks, when I went to a Fore return system it did not come with a sending unit either. The 07-09 gt500 sending unit is like $160
GLWS, these are real hard to find
