FRPP GT500 Dual Pump Kit
swflastang05
Back for More
N. Ft. Myers, FL
For sale is a used GT500 dual pump kit in great condition complete (less the plastic sending unit & float assembly) with all harnesses and the extra fpdm, and relay, etc. I went with a return style system.. $450 shipped.
crownaviation
http://www.tudyno.com/
Broke dafuk down
I do not see the float or sending unit or sending unit bracket???? Complete??
Just a heads up so nobody is pissed later...
ONLY the 07 up GT500 brackets for the sending units will work on this.
If using a GT500 sending unit then only the 07-09 GT500 sending unit will work if from GT500. Later model GT500 sending units will not work.
Early 05-06 GT (non tsb) sending units (with the metal brackets) will work on those 07 up GT500 sending unit brackets but you have to have the gt500 bracket and those are not sold individually. The 05-06 GT bracket will not work on these pumps. None of the gray plastic GT sending units or brackets will work on this pump.
Sucks, when I went to a Fore return system it did not come with a sending unit either. The 07-09 gt500 sending unit is like $160
GLWS, these are real hard to find
swflastang05
Back for More
N. Ft. Myers, FL
Oh, thanks for pointing that out! Definitely not trying to piss anyone off about the sending unit. I didn't realize that normally comes with the kit. As you mentioned I had to transfer that to my new Fore hat. The original bracket however is still on the GT500 hat its just the plastic sending unit & float assembly I had to transfer. Here's the side with the bracket visible:
In light of the missing sending unit $400 shipped.
crownaviation
Broke dafuk down
That is good news for a buyer. A person can use an original 05-06 gt sending unit (pcb and float) and transfer it to that bracket. Can't be one from the gray sending units. The Gray ones were 07 up gt and any 05-06 gt that had the recall done or had the pump replaced.
Used complete fuel pumps from 05-06 gt are normally $50 shipped or less. I paid $25 shipped for the last one I bought to convert
Good price tho. I build those Damn harnesses and in parts/materials alone I spend over $200. You can but buy just the harness anymore
You also have a right hand fpdm with the black bracket which is a good thing. Those will bolt right in with no hassle.
