its the fuel rail that hits nothing with the line i got areomotive rails and i have to grind 3/16 off the rail where it hits the bypass i just dont like the rails dont have a spot for the presure sensor
im feeding each fuel rail seprately im feeding the fuel rails in the front and plugging both back ports is that a good setupI put my sensor on the distribution block I used to feed both rails (2nd pic) but I rerouted my fuel lines into a dual feed set up. Are you using a crossover or feeding each rail separately?
i didnt mount it yet but with the fuel rails feeding from the front and both ports plugged back of rails what is this set up called and there is no return to the tank?That's what I did. Where did you mount your rail pressure sensor?
