Fuel rails
14R1
California
A couple of years ago I completed a top end rebuild on my 2008 mustang gt and props to Lito for the tuning aspect of it. Some of the parts that were installed was a jegs fabricated intake manifold (which is identical if not the same to hollys sniper intake), 47lb injectors and a set of BBK fuel rails. As of a week ago and less than 10,000 miles the BBK fuel rail on the drivers side have been leaking from the bottom where the pressure sensor mounts to the rails. I have seen reviews where this is also the case for other people. After researching and looking at different parts I have found these gt500 fuel rails ( https://www.revanracing.com/products/gt500-fuel-rails.html .) After talking with a member at Revan Racing he said that he was not sure that the fuel rails from that kit would fit my intake. This sparks another question aside from being able to mount them on the intake, would the injectors be to short/long for them? Has anyone ever mounted a stock or aftermarket set of gt500 rails on their jegs or holly manifold or would someone have the dimensions including the mounting points of both fuel rails? Below shows the build completed and the second photo is where it is leaking.
07 Boss
Sin City
I believe the mounting tabs on the fuel rails are slightly different. If your BBK rails are for the 4.6 3v then get replacements for a 4.6 3v. I have an Aeromotive set up in mine and have an inline sensor adaptor on one the fuel lines as opposed to the actual rail.
14R1
California
Are you able to add a picture of your setup, and what other components did you need for your sensor adapter
07 Boss
Sin City
Here is the adaptor with the sensor on it.
Below is where I mounted it. The silver square piece is for my fuel pressure gauge. Then the line splits into two and the pressure sensor is on one of the feed lines.
