Chim-Chim
Will drive for food
I did cut the perches off and with that done, I can run an 8" spring or a 10" spring (only on rates at 225 lbs or below). Right now I have 8" 275 lb Hypercos up front and 10" 225 lb in the rear.
Second-
Sport springs are NOT 'Good STIFF SPRINGS' they are barely an upgrade when you are open tracking. They just don't have the rate needed to control the car appropriately when aggressively braking from 120+, and handling high speed sweepers. Perhaps they work OK when dodging cones, but not on a real track.
Third-
True coilovers in the rear DO NOT cause deformation of the rear shock mount on these cars, THIS IS AN INTERNET MYTH. It is reinforced by an angle adapter that displaces the load to the VERTICAL sheet metal, which is plenty strong for the car on the track. The reason you see racecars with reinforcement bars as part of the cage is just to further stiffen the chassis, something you need every bit of in head to head racing. For open tracking, the rear coilovers work fine without any other reinforcement than comes with the kits. Give Griggs, Cortex, Moton... a call if you don't believe me.
Sports and Ultralites aren't the stiffest, but they're a good, inexpensive compromise if your car is mainly driven on the street, which is what I gathered from the OP's post is how his car will be mostly driven.
Performance Autosport has been building SEMA,Street and Race S197s since 2005 with rear coil overs and have had Zero issues.
Our American Iron car has a simple washer weled to the top of the shock tower to benter the shock mount bit that is all. Our driver is no virgin when it comes to the rumble strips and so far no issues.
Sky Render,
I too am running the Steeda Ultralites with the TSW Nurburgrings....Not too low and just enough negative camber for my occasional road course work.....Nice set up
Does anybody have any pics of the struts set up with this GC kit? And pics of the rear spring perch setup?
Just pulled this out of the car, for those that wanted to see pics of the kit...
I didn't. though the strut mounts have so much adjustment that if you want to max them out you need to open up the hole in the strut tower. not allowed in SM so i haven't.Did you have to modify the vehicle in any way to install that?
What were/are the front spring rates? Can't tell from the picture.Just pulled this out of the car, for those that wanted to see pics of the kit...
