Koni yellow modified for GC coilovers w/ steeda CC plates
one eyed willy
Pizzle fo shizzle
Lakeland FL
http://www.tunersports.com/koni-sport-series-yellow-shocks-8741-1494sport-8241-1240sport_p19763.html
http://thmotorsports.com/i-150601.a...type=pla&kw=&gclid=CMrumLnn27YCFUWo4AodbzEAdw
Koni yellows have approx 25K miles on them , ground control coilovers have approx 15K miles.
To add the ground control coilovers, the spring perches and sway bar mount had to be removed from the Koni yellows, a metal collar had to be welded on as the new perch for the coilovers and a new sway bar mount was added. The welds are not the cleanest but its on the back of the strut and its held good for few thousand miles now.
I switched out to BC coilovers. Because of the mileage, and the modifications I made to the Koni's, I'm letting these go for cheap.ive had these on the car for 2-3 years.Comes with the Koni plastic adjustable knobs and ground control spanner wrenches. I recently repainted the front struts.
I've always felt these ride great, they make a bit of noise at low speeds when turning the wheel...which my new BC coilovers do as well, I think it's just part of having coilovers.
Yellows usually go for $700-$800, coilover kit is $425....retail.
Selling this combo for $500+shipping
If you add another $150 ill throw in the steeda camber plates for just $150 ( I have these listed for $200 seperatly in another post)
So $650 + shipping for Koni yellows front/rear, ground control coilover kit and steeda camber plates.
one eyed willy
Pizzle fo shizzle
Lakeland FL
I thought it would be a upgrade....but it doesn't ride much different with the BC, little more firm but that's probably just because the spring rates are a little more stiff on the BC. I'm not switching them back at this point.
