heat exchanger coolant temps/efficiency
S
santi_bh88
Guest
Well, here's an update to this thread:
I decided to try another low dollar mod to my hodge podge heat exchanger loop. I bought two 5" spahl fans (315cfm each) and added them to the original roush heat exchanger that came with the kit. It was a little bit of work, and about $130 dollars in parts to add the fans, including new coolant in the loop. Early results appear to be impressive so far, but I don't have any significant driving time, so I'll just post a pic of the set up I installed, and post temperature data in a few days.
Man i think is waste the money, I got an afco dual pass HE por $250 on eBay in decent good shape for a friend and that is a huge difference.
S
santi_bh88
Guest
Thanks. I can't describe how helpful your posts are. You've contributed wonderfully to the thread. Thanks again.
Isn't helpfull to tell you there are cheap afco on eBay if you don't want to spend a lot of cash... then you spend 120 in two fans... what words do you want to hear?
