I just replaced a cracked bellhousing and clutch on my 07 gt. also got a hurst shifter as well. Got everything back together. But now the car won't shift into gear at all! Everything looks fine?? When doing the bellhousing I undid the torx bits and removed the springs and follower looking thing for the shift rails so I could slip the bellhousing on and off. Put them all back in how they were. And tightened them. I know when I put the trans up it was in neutral and I could spin the tail shaft. Now I can't? And the driveshaft is still off. Any help would be appreciated!
