i was thinking of buying the carbon fiber trim kits for my 06. the ones for the dash and everything. just wondering if you have to use anything special to clean it?
As long as the carbon fiber has a coating on it(if it is smooth/shiny there is a coating) then you can pretty much treat it like a painted surface. If not then you shouldn't use any waxes or polishes because it can get caught in the nooks and crannies.
I have had numerous CF parts before, and you kinda want to be fairly careful not to use anything abrasive on the clear coat, because it will scratch fairly easily.
Just warm soapy water, and then dry it off and you shouldn't have a problem.
