In need of help with crank no start
Squatch71
Ok i have a 2010 mustang gt 4.6 3v with a automatic.i was driving it and was behind somrone who was turning, i was slowing down and just about to a stop and the car was downshifting and as soon as the guy turned it shifterd in to first and at the same time i gassed it and it hit the rev limiter, it started stumbling and finally died and i coasted to a nearby parking lot.it tried to start a couple of times like it was on 2 cylinders and died then it quit trying to start and just turns over.i towed it home,the battery died from all the cranking so i charged it back up and of coarse the codes were not there when i scanned it.i had new coil packs so i replaced them all and new plugs,still wont start,so ive changed cam sensors,crank sensors amd fuel rail pressure sensor still no start so i checked and its not getting fire to the plugs but it has power at the coils, theres no codes,no blown fuses, fuel pump is working . Has anyone else had this problem and can toss out some places to check? The pcm is working ,had new key made thinking maybe the key broke.thanks in advance
Iceman62
Bullitt 6005
NE
Would be nice to have some history 1st...any mods (performance, electrical, etc.)???
Squatch71
Rattler cams tune and a gear is all since ive had it,before me im unsure
Squatch71
Talked to ford tech,he thinks i bronke the tone ring on the crank that the sensor reads, im going to check it when i get home
I fear that when you gassed the car and the engine hit the rev limiter, something in the camshaft drive system broke and caused a timing chain to skip a few teeth. Since the 4.6 is an interference engine, it's possible the pistons may have made contact with the valves in a couple of cylinders.
JC SSP
FL
Dino could he pull all the spark plugs and with a bore scope do a quick inspection for valve to piston contact?
Yes he could do that. He could also do a compression check if he doesn't have a bore scope. If a valve is bent and unable to close properly, that cylinder will show zero compression.
