ok am rebuilding my 3v 4.6 and figure see if a can save a few bucks. here the list am looking for so far.
valve springs (running 127500 cam so at least 500 lift spring)
rod and main bearings std
piston rings std
stall converter for 5r55s (min 3000rpm)
1 pc drive shaft
not sure how it will run or if I can rebuild a engine to stay running but hopefully be good build to hit in the 10's.
what have so far.
boss 302 rods with flat top pistons
holley sniper intake with 62mm throttle body
410 gears
wet nozzle kit hope for 200 shot.
piston rings std
1 pc drive shaft
what have so far.
410 gears
