I got my car back yesterday from getting 4.10s installed. I had the trac lok rebuilt while it was out so I wouldn't have any issues later on. All the work was performed by a ford tech who is the one does the rear end and transmission work at my local ford dealership. My car is lowered on bmr lowering springs and has a spydershaft one piece drive shaft. Before the install the drive shaft would only hit when running 80mph or more and hitting a big pothole. I have put 120 miles on it so far so I haven't gotten very hard as far as spinning but I've kicked on it a couple of times trying to break it in first. Every time i leave semi hard on it the drive shaft hits underneath my console bad. Also when i picked it up yesterday I didn't notice any noise but driving today I noticed that when I left off the gas the rear end has a hum to it. Also I have a clunk in the back that was not there before it sounds like what a lower control arm sounds like if the bolt isn't torqued with a load. I emailed him to ask about everything and his response was he could see where the drive shaft was hitting before and that he didn't touch the LCA so they should be the same. To top it all off bama wrote my tune for 3.31 gears still so my speedometer was off and shift points are off as well as the lock up for my circle d converter. Changed the speedometer so its right now but shift points are still off.
So my problem list is
Rear end whine/hum when off the gas
Drive shaft hitting underneath console when taking off hard
Rear end clunk when hitting ruff spots in the road
Thanks for any advice you can give.
