Failborne
So been having a rough idle issue for the last two weeks, been trying to self trouble shoot getting advice from my tuner, even adjusting the tune a few times. I had the boss intake manifold, Accufab TB, and JLT CF CAI on the car for about 5 days before I put the BBK LT's and O/R X. Same tune. Started getting the rough idle after I put the headers on. I have taken the intake manifold off and reinstalledntondouble check everything... Checked all vacuum lines via smoke test, checked all connections. I ran the car for a couple days only with one upstream O2 sensor because I couldn't get B2 connected. Is there anything I'm missing to check or do before I spend money taking it to someone? Idle is bad enough to stall the engine at times, and what confuses me is it isn't all the time, sometimes she idles fine sometimes rough, seems to be worse when the heater is on. Thanks - Kris
