LED fogs
rb042hou
Installed gt grille with led fogs. Bought Starkey harness adapter for H-11 wiring harness. ? How many amps to turn on lights. Don't want to overload and burn them out. Any help would be greatly appreciated.Thanks
redfirepearlgt
Should be an amperage rating per lamp in the documentation that came with them. Take that number multiply by 2. That will tell you the total current draw on the two lights and if the circuit of choice can handle them. Rule of thumb is 75-80% current draw in the fuse rating...meaning if the circuit draws 7.5 amps, a 10 amp fuse should be used.
