Heaten m90
- Joined
- Jun 3, 2017
- Posts
- 335
- Reaction score
- 8
I see, well “bump stops” is definitely more of an appropriate nomenclature for these units, but they do look like yellow cakes and are so not racecar esk
I did cut them down a notchI see, well “bump stops” is definitely more of an appropriate nomenclature for these units, but they do look like yellow cakes and are so not racecar esk
Read the install manual I provided. As it states that is a one time use bolt. That is why they send a new one with the Upper relocation bracket. 200 ft/lb is a ton of torque. So if you removed that upper bracket for whatever reason, you may wish to replace the bolt as well as verify that the torque is properly set.And don't forget to check the lower bolts that go up through the bottom to ensure they are torqued to 85 ft/lb. Again this is all assuming for whatever reason you removed the stock bracket to install the aftermarket UCA.
The LCA bolts are only torqued to 129 ft/lb but they as well are considered to be a one time use. People reuse them as I have. But when it comes to torque levels at 200 ft/lb where it is specified one time use I become much more compliant. It's not a TTY application bolt (which should never ever be reused) but the level of torque being placed upon it when it is tightened is a mass amount.
