Loud, low pitched hum at 70+
BuckeyeBOSS
My 05 GT has a loud, low pitched hum at 70+ mph and a very slight vibration, but the vibration is barely noticeable. Not sure what it is. I had the tires checked out and rebalanced this weekend, but it's still there. Maybe low on rearend fluid or a driveshaft issue? Anyone had this or have any ideas? Thanks.
08gt4u
mines is not loud but is noticible with the radio and ac off on a quiet night.mines have been doing it for a year now and i have had the oil from the diff replace,gears check,drive shaft rotated in every possible way and is still there.i have learn to live with it but has not affect in performance one bit.
kevinatfms
EX-ford tech(6 years)
MD
install the axle weights from the tsb, it will remove unwanted axle whine/groan/hum at crusing and decel speeds...once installed if you have anymore noise then it will be bad pinion bearings
also you can check by turning sharply left to right and see if it changes pitch, if it changes pitch you have axle bearings going bad
and finally if you are more mechanically inclined, jack the car up and secure firmly
run the rear wheels up to 70mph and use a stethoscope to pin poin which bearing exactly is going bad
BuckeyeBOSS
Awesome, thanks man. Does the dealership have to install these weights for free or not? I hope it's not the bearings, the car only has 22k miles.
Dread53
Woodland Park, CO - 9000 ft!
Do you have a 1 piece DS? Mine does something similar at speed. No noise, but a cyclic low vibration. I've never tried re-indexing the shaft because it isn't that bad. Lots of people have had driveshaft balance issues, especially with the 1 piece.
kevinatfms
MD
your car is out of warranty, you will have to pay for it, if you buy the parts you can install them yourself...ill pm you tomorrow with the part number if someone doesnt do it on here before then
BuckeyeBOSS
Cool, thanks man.
gzmo
Maybe the type of tires you have? Every tire is different and omits different road noises. I would take a look at some reviews to see what people say about them and if they complain about noises at high speeds.
kevinatfms
MD
part number is: 5R3Z-3C246-A
and to install is just tightening them down with a 15mm socket and wrench
takes all of about 10 min to do
BuckeyeBOSS
Stock tires
Thanks man, I'll give it a shot
1FastS197
Hickory MS
i have tore the rear end down three times now try'n to find the hum (also a '05 GT)... i have come to the conclusion of "FUCK IT"... i will fix it when it breaks... gears look great, bearings are fine, no metal shavings, no slack in the diff, etc... i'm just gonna cut the radio up...
BuckeyeBOSS
Have you tried these axle weights?
BuckeyeBOSS
Well, I got this axle weight kit and went to install. They "appear" to be exactly the same weights already on the axle, minus some rust. Are they different in anyway?
MikeVistaBlue06
Inventor: Asshole Points
Richardson TX
I too had vibe problems with my single piece driveshaft at about 65mph. I had it removed and rebalanced. It was way the fuck off balance. After it was balanced, I have no more vibe at any speed!
If you have a single piece driveshaft, you may want to have it yanked and balanced.
HTH
Mike
BuckeyeBOSS
HTH
Mike
Thanks guys, I'll look into this next.
smoken1986
Lynchburg, Va
I too have the vib at 70-80, mine will disapear if I drop into 4th gear though. Is your car a stick? You might want to try that. I read somewhere that a bad bushing in the trans causes it, but I have not pulled mine apart to check yet.
BuckeyeBOSS
Mine's an auto, I took it off OD and let it downshift at 70, made no difference.
smoken1986
Lynchburg, Va
Sounds like a bearing issue or driveshaft then. Not to ask you to drive crazy or anything but does it change pitch if you change lanes fast or move the weight of the car back and forth. If it does it could be a axle bearing or axle, if not I would say pinion bearing or driveshaft. Do you still have the stock 2 pc shaft? Just throwing some things out there for ya
