Nice runs guys!!
Earl
Earl
Ran 8.45 on 7 Cylinders which was a PB.
Changed the oil this morning and had pins in on the drain plug. Pulled the Valve covers and had 3 broke followers from number 4, which probably happened before my last run were it would not build boost due to a vac leak, it pinged pretty hard when I got up on the brake.
ARGGG!!!!
Sorry James
Track prep was good new PB 60' 1.463:
A friend tells me he has a photo of this runs launch.
Ben that is an awesome speed! I figured that would be enough for 9's. What are you thinking? Its soooo close!
great 60' (safe to assume that was on the spray?) - hurry up and post that launch pic!
Pic isn't super clear he did a screen capture off the video.
Assumption confirmed - 100 shot on totally stock long block
Ray, if you listen closely it sounds like the car flattens out a little, at the top of 4th gear. Could be more in it if you get that fixed.
Earl
