Blackbird1084
- Joined
- May 15, 2011
- Posts
- 945
- Reaction score
- 0
A few months ago the motor in my TA suffered complete destruction. It was a 355ci lt1, stock crank, stock rods, kb pistons, 11.3:1 compression, afr 180cc heads, comp 306 cam, 1.7i/1.6e scorpion rockers (.578/.576 lift), ported edelbrock intake, 30lb frpp injectors, and 58mm tb. I was planning on starting from scratch and building a 383 but I was having problems finding a good block. Untill I found an already built 383 on eBay. Here's the specs on the new motor.
JE 181920 11.89:1cr@56CC FORGED PISTONS,$600
SCAT 4340 STEEL 5.700" H-BEAM RODS WITH ARP BOLTS,
*$300 SCAT 4340 NITRIDED 3.750" STROKER CRANKSHAFT $500 SPLAYED 4BOLT MAIN CAPS W/22 ANGLE AND ARP 4 BOLT MAIN CAP STUD KIT $150
LUNATI FILE FIT PLASMA MOLY RINGS $75
AFR 1057 210cc LT4 STREET HEADS W/56cc CHAMBERS, PORTED AND POLISHED BY LLOYD ELLIOT $1900 + PORT AND POLISH $500
K-MOTION K-1100 VALVE SPRINGS $130
JESEL KSS-336060 SHAFT MOUNTED 1.6 ROLLER ROCKERS $950
COMP-CAMS SOLID LIFT ROLLER CAMSHAFT .639 INT .646 EXH , 254/270 DURATION, 105.5 LOBE SEPERATION $350
COMP-CAMS SOLID ROLLER LIFTERS $750
MOROSO OIL PAN W/MOROSO OIL BAFFLE $125
COMP CAMS 5/16 MAGNUM PUSHRODS $100 CSR ELECTRIC WATER PUMP $180
PIONEER 872044/872015 BALANCER AND PULLEY $175
MSD 84811 95-97 LT1 DISTRIBUTOR CAP AND ROTOR, MSD IGNITION COIL $175
EDELBROCK VICTOR EFI CUSTOM INTAKE, EDELBROCK BILLET FUEL RAILS $500
DELPHI 32LB INJECTORS BY RACETRONIX $200
SCAT SFI APPROVED 153 TOOTH FLYWHEEL $45
HAMBURGER STARTER $150
THIS IS ALL WELL OVER $7,000.00 WORTH OF PARTS I paid $3000 for it and plan on having it back on the road soon. Oh my goals for this car is 10's n/a.
