Rick Simons
- Joined
- Sep 27, 2019
- Posts
- 250
- Reaction score
- 61
This weekend I re-installed the JLT CAI, making sure that there was a good seal between the intake tube and the MAF- a leak here is what caused an intermittent full-lean condition that I mentioned in a post last year. I also loaded the appropriate tune for the CAI. With the CAI the engine has a stumble/hesitation when I blip the throttle quickly enough from idle. If I blip it fast/far enough, I'll get the hesitation AND a backfire. Note that this is only from idle; from 1k rpm and up it responds perfectly. I've checked every possible vacuum leak source I could think of, and nothing. No CEL either. If I put the stock air filter setup up back on and load the tune for it the throttle response is perfect everywhere. I've reached out to Lito to see if he has any ideas.
Open to any suggestions; thanks!
