BMWM3
Always Online
Ok my tuner tuned my car with a good safe tune making low boost and I made around 530/475. The care runs perfect when he dogs it out, but the problem he is having when idle'ing the car wideband gauge will stutter and jump from 14 to 17 and back and forth, also when idling it will show it going lean and then going rich back and forth in the logs... he thinks their is vacume leak but can't find it as of yet.... He thinks he is going to have to run a fogger in the intake to find the leak.... Any body have ideas of where I can point him to..... In the tune Log he showed me only at idle there is a problem on 1st table of log... Any guys experience any problem with idle with prochargers p1sc.
2nd issue is that the procharger tube in pictures below he said he doesn't remember seeing one like this with the way the tubing is made has anyway else seen one like this.. He stated the ones he seen have no internals like this one to direct air flow.
My mods are
BRENSPEED 5.0 STROKER
D.S.S PORTED HEADS UPGRADED SPRINGS STOCK CAMS
PROCHARGER P1SC 12LBS
FORD RACING INTAKE MANIFOLD
EVERYTHING ELSE STOCK INCLUDING SUSPENSION
My mods are
