Need Help with Driveshaft Issue's
TurboPete
Miami, Fl
Ok any help would be greatly appreciated. WHAT have you guys heard about the BMR Carbon Fiber Driveshafts?
I installed mine with the upgraded yoke. Its rated for over 1000 hp (not that Ill be at that power level) but its supposed to be the s%^&.
Car has a vibration at 85 to 90 and up MPH. I set the pinion angle at -2* and also already clocked the driveshaft over to next bolt hole , but still vibrates . Is there a Driveshaft out there for the Automatic Cars that doesn't vibrate?
Should I go to a drivetrain specialist and have the check out the shaft to see if it is balanced or what should I do , Im frustrated and ahhhhhhhhhhh.
Pete
kenneth
Louisiana
never heard much about thier driveshafts, most people are running the spyder or the powerhouse driveshafts with no problems.
KIMMER
Admin
I seriously think there is an issue with our cars and that's why ford put the 2 piece shaft in. Hopefully someone figures it out.
Born To Run
Woodstock,Ontario
Driveshaft
Send it back ASAP,tell Lee it vibrates.I got one from them in March/07,it vibrated at 75-80 & beyond.I could not send mine back as i was away for 2 months.My first driveshaft was Driveshaft Shop steel,it vibrated the worst.My car is a manual trans & pinion angle will not help you.The problem is in the tiny slip joint they all use.I finally got one from Ron @ Spydershaft,he told me if it vibrates send it back right away & he would refund the full purchase price.I have no problem with ron's driveshaft,i have 75 hard passes on it with 480 RWHP & Torque.My pinion is also @ -2 as well.Good luck.
spyder7724
Maryland
PM Sent! Would I need to upgrade to a 1350 u-joint. Is it necessary?
Please PM Me with info.
Pete
i made this an option cause a few customers have asked about it but for 90% of us it's overkill. The standard 1330 u-joints are plenty strong enough and we've not had any reports of problems with them.
Born To Run
Woodstock,Ontario
Driveshaft
All driveshafts with a reduced size slip joint will vibrate on our cars.Some people have been lucky,you only hear of the ones that have problems & that is alot.Send back the Carbon$$ Fibre$$$ one & get your money back!! Talk to LEE
TurboPete
Miami, Fl
Just wanted to update everyone.
I received my DS today and installed it. WOW! What a difference. My car feels as smooth as when it was stock. Thanks to everyone for posting there experience with Ron at Spydershaft.
Im so glad I took everyones advise and Thanks again Ron for everything.
Took the car up to 110 and didn't feel any vibration , It felt perfect .
Thanks Again,
Pete
SteveP
Modular Specialist
Boynton Beach, FL
I have the stock one in mine still. I have been looking all over for a good one but i read good and bad things about everything. Ranging from $500-1000. With the 522rwhp i thinkits time to upgrade soon seeing how by spring i will be at 600ish rwhp.
Thanks
spyder7724
Maryland
Thanks
just PM if I can help or answer any questions for you. or ask around we have sold about 300 Spydershafts to members here, dealers and multiple other message boards.
oh and pete, glad it worked well for you:)
spyder7724
Maryland
Thanks Again,
Pete
Pete was your previous driveshaft a carbon fiber or aluminum?
thanks
