NEW Whipple 2.9L/ 2011-2014 SAVE $$$$
GI Joe
NEW Whipple 2.9L/ 2011-2015 SAVE $$$$
NEW Whipple 2.9L S/C for 2011-2015 Mustang 5.0 …SAVE $$$$
No other upgrades required…includes anodized billet fuel rails, new 58# injectors, new spark plugs, even the tune w/handheld. Massive power right out of the box. NEW in the box.
Here are some things Whipple has for say about it:
•Front entry W175ax (2.9 liters) Whipple twin-screw supercharger that significantly outperforms competitions 1.9L and 2.3L roots-type systems
•2.9L 26% larger than 2.3L roots-type Front feed supercharger utilizes precision ground helical cut gears vs a problematic belt
•Oversized Crusher™ inlet for maximum airflow capacity and minimal rotor cavitation
•Front feed allows for oversized intercooler core compared to other smaller intercooler cores giving Whipple lower air charge temps which allows more boost and timing to be run on pump gas
•Massive air-to-water aluminum bar-plate intercooler offers more cooling than any other positive displacement system available, nothing comes close
•Large intercooler heat exchanger, nearly 150% more volume then some competitors
•Massive oversized aluminum intercooler reservoir (over 2 gallons) holds more than double any competitors IC water system allowing longer more consistent power
•More boost at the "hit" than any other twin-screw Flat torque curve for incredible acceleration
•Fits under factory hood with no modifications No internal modifications required.. No grinding of engine block
•SCT X4 flash tool and tune included: Whipple engineers have developed a unique PCM calibration that reconfigures all the necessary engine functions including fuel, spark, knock detection, torque management, transmission control and electronic throttle control. The vehicles PCM constantly monitors the engines torque output while monitoring many different parameters to keep the engine in it’s ideal parameters. If a parameter falls below specification, the PCM will lower torque output until the problem can be cured. No other supercharger system has such technology, giving the Whipple SC system unheralded performance and reliability
•Completed installation looks factory installed.
•Kits come complete with all necessary parts and hardware for installation
•Unique oil level sight glass for easy oil level and quality check, no dipstick to bind or misread
•Plug and play wiring with male and female connections
•Proven 6-rib belt system with heavy duty spring loaded tensioner and adjustable idler system
•3 minute pulley changes with lightweight S/C pulleys
I also have as an option the 132mm oval throttle body to add 40 + hp
With this throttle body you will make 700 plus horsepower.
Read more here:
https://whipplesuperchargers.com/index.php?dispatch=products.view&product_id=294
Whipple sells S/C for $7500, plugs $100, shipping $300, and $600 for throttle body for a total of $8500 shipped.
I will sell the complete kit with the throttle body for $6900 and
Without the throttle body for $6400…that’s cheaper than a 2.3L
AND I will pay shipping up to $200 which will cover most places in the USA
SOLD
