Nitrous Pressure Gauge Install
waketek516
Pedal to the Metal!
Costa Mesa, CA
Hey guys,
When hooking up a nitrous pressure gauge (autometer cobalt gauge mounted on the dash) is it better to mount the sensor on the bottle, or further down the system near the manifold?
Would you want the reading closer to the bottle, or closer to the intake so you know exactly what you're spraying?
Also - if I mount on the dash, and end up putting the sensor on the bottle, I'm guessing I'll need this:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390297589997&viewitem=&sspagename=STRK%3AMEWAX%3AIT
Thanks
-Tommy
Kuro!
Banned
Austin, TX
I put a 1/8 npt adapter on the outlet of bottle and monitored it from there.
If you don't feel comfortable cutting and re-soldering your gauge harness go ahead and buy that one.
5.0lightning
Guest
I run mine with an adapter near the solenoid/NMU box. I first had mine in a triple gauge pod on the pillar. I ran the wires next to the driver fender and around the door then behind and up the kick panel to the gauge. I did not need to extend the wires when I had them there. I now have my gauge in the cup holder and needed to extend the wires. Save the money if you already have wire and connectors and extend them yourself. My electrical gauge and mechanical gauge on the bottle read nearly identical. I would mount it on either end and call it a day.
I also ran my electrical fuel pressure gauge to the drivers side vent the same way into a Roush vent pod without needing to extend the wires.
