Your stockers are a little different then mine. Haha. Unless yours is a clone. Our pirellis are terrible.
I don't really drive stupid in the rain but traction control has saved my butt a few times. Haha.
^^^^ do you have that backwards? Isn't 45 rear cause it's taller right?
Yea true my stockers are a little different lol.
I will most likely be going to invo's next and pick up a set of slicks for the track just because in the summer I drive the shit out of the car
I'm not sure how this works but I can tell you a wider tire plays a role in how tall it is. For example, a 285/40/18 is taller then ur 255/40/18.
http://www.1010tires.com/tiresizecalculator.asp
^^^^Heres a link that cal the tire size for you, I find it to be helpful. If you cal both 255/45 and te 285/40, you see there close in height.
I bought my 18's already and the tire size options are horrible for 18's little to low profile for my taste. I got 18's to get away from that. Destroyed my 20's on two separate occasions.
I was thinking of a 295/45 in the back and 255/40 in the front. Anyone see a problem with running a smaller diameter in the front? I don't have tps but would it effect anything else on the car? I like the nostalgic look.
I think I'm gonna go with Nitto 555's 255/45/18 in the front and 295/45/18 rears. Unless Im missing anything there's about an 1.40" difference in height but they both look like they fit anyone see any issues with these sizes?
I still think you should copy the shelby and do 285/40/18
im pretty sure a 28" tire doesnt affect mine much at all...... if its too much tire than add more power!
I run the BFG KDW 2's in 245/45/18 for the fronts for my summer tire setup with MT DR/s in 305/45/18 in the back on ZE Boost wheels. I have a set of BFG's in 245/45/18 front and rear on Shelby Razors that I run the rest of the year. The BFG's are a great all around tire and give excellent traction wet and dry. They are a little noisier than some tires due to the aggressive tread pattern but offer great handling qualities. They even do well in the winter temps and I run them all winter. If you really need your car for a daily driver I wouldn't run DR's on the rear unless you can stay off high speed roads when they are wet. DR's in the rain IMHO are only good for about 45 mph and then only when driven carefully. It is very easy to lose it with a DR on wet roads.
Earl
