When I pulled the Whipple off for the winter teardown I noticed a significant amount of oil in the intake tube where the factory dump from the passenger side valve/cam cover is..So like a few others on here I decided a catch can was in order. I like doing things a little different than most so since I already had the cam/valve cover off anyway. I ground off the heads that hold the mist tray/tube in place. Once that was gone and out of the way I took my dremel tool and enlarged the factory hole until I could tap it with 3/4 pipe threads and screwed a 12 AN fitting into it so I have a neat looking place to attach the 12 AN line that will run to the Moroso vented catch can..
