Once the rollbar is in.....
Greg@RET
Mad Torque Inc.
This is getting hooked up :rock:
psfracer
billy badass
Valencia, CA
How are you going to do this with the s/c set up? Will it be a dry or wet kit? Nozzle in the intake tube? or direct port on the intake runners after the s/c?
Greg@RET
Mad Torque Inc.
Wet kits are the only way to go. It will be in the intake tube :victory:
psfracer
billy badass
Valencia, CA
That is what I figured. But how do you make sure the mixture does not ignite before entering the cylinder? Would it ever get hot enough in the s/c to do that? Ever? I would think not, seeing how the max intake air temp I have data-logged are at a maximum of 156 degrees.
I have been trying to figure out what happened on my mishap, and the only thing I can think of is that something caused the intake valve to hang open, so the combustion in the cylinder traveled past the intake valve into the intake manifold, then BOOM!
Greg@RET
Mad Torque Inc.
I never had a issue with juice on the Cobra, and that was ran a bunch of times.
psfracer
billy badass
Valencia, CA
Oh, I didn't know you ran the juice on the cobra. You mean the cobra that ran 10.1 and 6.40's?
Greg@RET
Mad Torque Inc.
Yep.
I am still debating wich bar to get, but was looking at the MM bars. I know the 99-04 is obviously different, but I wonder how this would fit?
http://www.maximummotorsports.com/
I need to call up someone that owns this bar and take some measurements.
