Open end lug question
mikeysgt
Bakersfield, CA
So i realized i need some longer stud up front for the summit stars due to the spacer needed to clear the calipers. Purchased the studs yesterday...
these --> http://store.summitracing.com/partdetail.asp?autofilter=1&part=ARP-100-7722&N=700+0&autoview=sku
now i need some help choosing the open end lugs. i did some looking around and i think i narrowed it down to these if i'm correct.... just not sure which ones are the ones i need since one they are different lengths and they say lugs with washers?? never ran an open end lug before but want to make sure i get the right ones that will work with the setup before i make the purchase. narrowed it down to these four..
McGard 63004 - http://store.summitracing.com/partd...4294900366+400067+4294900339+115&autoview=sku
McGard 63000 - http://store.summitracing.com/partd...4294900366+400067+4294900339+115&autoview=sku
McGard 60127 - http://store.summitracing.com/partd...4294900366+400067+4294900339+115&autoview=sku
McGard 61005 - http://store.summitracing.com/partd...4294900366+400067+4294900339+115&autoview=sku
can anyone point me to the correct ones i need for this? the cheaper the better :thumb:
TC05GT
None of those. They are all shank style lugs. With the Summit wheels you'll need a 60 degree conical seat nut.
Any parts store or local place probably has that style in stock for cheap. OEM replacement nuts for the most part.
Something like this...
http://store.summitracing.com/partd...900366+4294902780+4294900339+115&autoview=sku
don_w
Dyno Numbers - Who Cares?
San Diego, CA
Beat me to it by a couple minutes. I was going to say the same thing.
mikeysgt
Bakersfield, CA
Thanks! had a feeling those weren't what i needed. so pretty much any open end lug that is the 1/2-20 RH in. will work?
