The Steeda mounts are garbage. If you pull the "through bolt" to either adjust the height of unbolt the motor mount the entire thing comes apart and parts fall into the K-Member. Dumbest thing I have ever seen.
Prothane FTW.
Install it once, using whatever spacer config you want, then forget about it. I wanted a 1/4" eng drop, that's it. No more, no less. You can't go too low anyway, or you will hit the steering shaft.
