Ordered some parts :-)
fastregalwe2
Need more powa!
Virginia Beach, VA
So far I have on my 08 Saleen:
3.2 pulley (11psi)
KB BAP
JLT 110mm CAI
62mm TB
N2MB WOT Box
Exedy Mch 500 Stage 3 clutch
Exedy lightweight steel flywheel
aluminum d-shaft
Saleen Extreme heat exchanger with dual fans
4.10 gears
Hurst comp shifter
Brenspeed tunes
BBK ORX
Flowcrapper single chamber 40's
misc other mods
I ordered MAC longtubes and a MAC Pro Chamber along with a CHE trans brace with TQ limiters. THinking about ordering the BMR solid motor mounts as well and a Lund tune.
The best ET before clutch, heat exchanger, d-shaft was 11.83. Best MPH to date is 121. Hoping these will get me to 125mph.
Cant wait to install the headers!! I know its gotta be choking on the factory iron manifolds.
MassMustang
Southeastern Mass
Nice choice!
Do you experience the 2nd-3rd shift issue? It happens to me when it's heated up and accelerating hard. I'm curious if the CHE brace actually fixes that.
fastregalwe2
Need more powa!
Virginia Beach, VA
I do. I had it on the car a couple years ago and it fixed all the shifting issues. I had parted with the car for awhile and I removed before hand. It def helps. I would def recommend it.
MassMustang
Southeastern Mass
Nice to hear! I also heard the MGW shifter resolves the 2nd-3rd hard shift issue. A couple of people in my car club offered to let me try out their cars (w/ MGWs). I'll let them try mine with the 4.56 gears. :)
Let's hear a sound clip once you get the LTs installed. I'm working on my Kooks.
fastregalwe2
Need more powa!
Virginia Beach, VA
It doesn't really sound much different. Just a little deeper and cleaner exhaust note. The blower is actually really loud now. I'm assuming because the engine can now breathe. Quite disappointed in the figment of the MACs. Had to shim my motor mounts and inch higher to clear the steering shaft. Also had to drill the pipe to header flange with a step bit because it wasn't wide enough for the header studs to pass through.
