Travis Belair
This car had the fuse box/wires melting like many have had. It was fixed with two relays outside the fuse box on the inner fender. It has had issues still with no high speed fan. I replaced the fan with a GT500 as I plan to autocross and race it. I thought maybe the computer isn't sending the signal to ground the relay and close it to run the fan. So I temporarily shorted the #85 wire to ground and the relay clicked close and fan started.
Well yesterday it got hot. I pulled over and confirmed the fan wasn't on. I unplugged the low speed relay and shorted the #85 wire to ground to close the relay and start the fan. I could hear and feel the relay closing and clicking. But the fan still would not turn on. I even swapped the low and high speed relays and tried again. Same thing, I hear it click and can feel click but still no fan. So the only thing would be the wiring between the relays and the plug that the fan harness plugged in.
Any thoughts? Im at a loss.
