P1SC and other parts
Memphis 05
I've got the p1 up for sale since upgrading to the F1..... It is the stage 1 kit with the Procharger intercooler. This was the kit that has the MAS in the turn down tube right at the TB. This kit has the top tubes polished and the lower ones are still stock grey. It is a perfect time to powder coat.....
This blower kit is out of a 05 car but will work with others. It does have a 8 rib set up. The crank pulley was just powder coated black. I have two of them with this kit. There is a 3.1 pulley on the blower. It was making 15 psi and made 700 Rwhp on my car ...strong blower for sure....
This was the dyno graph but your results will vary depending and your mods.
It is missing some items.
1. The water coolant crossover tubes for they are still in my car... You can get them from Procharger.
2. Mounting bracket and pulleys associated. ie the idler pulley and tension pulley. I'm calling Procharger today to check the price. I will update this with a price
3. My injectors are staying with the car. If you are running stock injectors.. It should work.
I also have fore hat with twin gt500 pumps with this kit. The car was upgraded to the new fore triple pump set Up. It was working when taken out.
Items are located in Atlanta ga.
I want to keep this as a kit but will separate the blower and fuel pump
Blower 2400.00 With fuel pump
The ride and PayPal fees are not included. Pm me for shipping quotes.
I still have a plenum cover and a CDC center console gauge pod for sale as well and will throw this in the sale. If I can find that stainless steel cover I will also include that in the sale too
This Is what it looked liked installed.
Memphis 05
Called Procharger and the prices for the parts are as follow. These are the prices from procharger you need to complete the kit....
Bracket 525
Coolant crossover. 161.
Changed price to 2400 plus the ride.
Memphis 05
bump.... make offers please!!! i want this thing gone.
Good blower and parts are there.... just not the mounting bracket....
yur2slo
Yur2Slo
AZ
Just a FYI the f1 bracket is different. It will mount to it but will flex a lot with out a support mount. The f1 bracket is beefier so it won't flex
Memphis 05
I didn't know that. Procharger never mentioned anything different.... That was the whole reason for not buying the bracket since we built our own tubes with the upgraded intercooler.
Thanks for the info.... I will call them Monday to find out and might have a new bracket....
Memphis 05
Thanks
After reading about this... I completely agree and will find a solution......
destava
how much are u selling it for and how much will it cost for the missing parts to complete it? and where about are u located at?
Memphis 05
Ok here is a lit of crap done to the car. It is a a lot.....
Forged bottom end with 19cc pistons on 9.05 to 1 compression, Manley h rods and Cobra stroker. Reg bore
Ported heads. With upgraded valve seats and springs.
Upgraded intercooler that isn't for sale. And larger piping that was costum made. Still not for sale in this kit....
Exhaust cut outs ford racing intake and throttle body.
Fore fuel triple hat with return style set up with larger fuel lines from the tank.
60 lb injectors
Pulley. 3.1 Reichard racing pulley
And most of all a good tune!!
Look what I am dying is that the power in the p1 is under estimated and you can make some power with it.
Again the kit needs parts. I have posted how much they will cost you from Procharger.
Hope this clears some things up.
Thanks for lookibg
Memphis 05
... Really want this gone to finish my project.
Someone one wants it...
Memphis 05
Have 60 lb injectors to go with this kit...... Trying to make this kit complete.
Memphis 05
Inter cooler yes.... Bypass valve I have to see if the Procharger one is still around. I upgraded to the tial bypass valve.
Not sure what you meant by mafia?
