speedfreak1000
2 sided tape expert
I had gears installed a few years back. about a year ago I noticed a little gear oil in the driveway, since I didn't drive it much i'd just top it off every few months. well after building the garage i noticed it was quit a bit leaking out so today I pulled the pinion seal out before I put a new one back is there anything I should check for? here are some pics, the shim that was in front of the bearing is dented alittle...should I replace it?
I just don't want to put a new seal in and it still leak.
