Well as you may be aware i jsut got my car back from the body shop. i also had the BMR A-arms installed as well as one of the stock arms was bent. They are super quiet and no added NVH but there is a problem. i have 9.5" rims up front running a 275/40/18 BFG tire. when i turn the wheel to either left or right extremes, the rim is scraping the BMR a-arm. these are the same rims i had before with no issue with the stock a-arms. here is a pic of where it is scraping
it makes a horrible noise when it scrapes obviously. I called BMR and spoke to jason and asked him if i could shave that piece of metal off, if it would cause any structural problems. he said i could take some off the straight part of the a-arm, but if i took it out of the elbow above, it may cause problems. im not sure how much further the wheel is suppsoed to turn either since it is hitting the a-arm currently. he said the a-arms are designed off the stock wheel (8in wide rim and stock tire). i find it hard to beleive many people are out there with the stock rims and tires. any ideas on what to do guys?
