crownaviation
http://www.tudyno.com/
Psshhhtt, you know who to hit up first, right?
Lol.. yeah I am planning on taking it out soon
OK, so getting back to degreeing cams... I'm having issues.
I got perfect TDC, set up my timing per trick flows instructions and set my cams to R6 (retarded 6 degrees).
When I degree the cams I am getting 111.5 and my cam card says 102. 102+6 is 108. Why am I off 3.5?
Maybe because they are calibrated for the 2v? Does anyone know the tooth count on a 2v sprocket?
OK, so now I am getting 109.5 to 110.5. I keep rotating the crank clockwise and taking the 0.050 before max lift and after max lift.
I keep getting 0.5 to 1.0 degree difference on the degree wheel with every rotation. It flip flops back and forth.
What the hell??
Its close to the 102 cam card spec plus 6 retard which should give me 108... I was hoping to get no more than 1 degree off.
You're turning the crank clockwise when you're taking these measurements, correct?
What are you getting with the stock crank gear.. or the adjustable set to zero?
Yes, I started following Trick Flows instructions of clockwise and counter clockwise rotations and I noticed inconsistencies, so I ended up only rotating clockwise (when facing the engine).
I never used the stock gears or set the adjustable to stock. I started off right off the bat at R6.
Should I have taken a baseline with the stock gears or set the adjustable to stock timing?
Update, I ended up retarding both cams to R4 and got 109.5 (76*/143*) on both LH and RH sides.
Should I try to get them closer to 108 target or leave them as is...?
I spent all day (a full day) learning how to degree cams... I think I got the hang of it... sigh
I am definitely getting consistent results now. Its just a major PITA to remove, install, check, remove, install check, remove install check... It would make it easier to have two dial indicator setups, two solid lash adjusters, and two rockers.
I am exhausted...
Update #2:
I just thought about it...why am I getting 109.5 when I set it to R4... Cam card specs 102 + 4 (retard) should give me 106...I'm getting 109.5. Thats 3.6 degrees off. What gives?
Maybe they aren't calibrated for a 3v? As long as you get something repeatable and it's in the range of what you want it will be ok. IMO 109.5 should be just fine with your 127450 cams. I'd ask your tuner though.
Wow, so it may not actually be the cams that are out of specs, but more so the stack up of parts.
I got it... Thank you for all your help guys!!
I feel confident about cam degree now!! Anyone need their cams degree-ed, I got it down pack after 17 hours total so far... lol
