darrens07gt
I'm at the tail end of installing a nitrous outlet plate kit with bottle heater, purge and NOS window switch. The arming switch & bottle heater switch need to be connected to a "key'd 12V source". I have them routed to my engine bay because I figured I could connect them to the positive terminal of the battery. But that's not really a key'd source since the battery is always on (so to speak).
One of the guys at Nitrous outlet told me they usually hook those up to the fuse box but didn't explain in any detail what that meant. I was looking at the fuse box in the engine bay near the passenger side headlight and noticed a harness assembly connects to the front of it with an O ring type connection and a bolt holding it down.
Is this a key'd 12 V source? Or should I stick with hooking them up to the positive terminal on the battery?
Thanks.
Thanks.
