I got the Summit Racing kit.
"These Summit ring and pinion installation kits give you everything you need (except axle bearings) to overhaul or install a Ford or GM rear end: differential bearings (cups and cones), front and rear pinion bearings (cups and cones), pinion positioning shims, pinion preload shims or crush collar, a pinion seal, pinion nut, a rear cover or housing gasket, and gear marking compound." (From the site)
Came with Timken Bearings and much cheaper. 72.95
Dont know if they still do come with Timken Though.
Truth be known there are only a few bearing makers in the world.
Most brands are just re-branded.
You also need RTV (High Heat), Anti-Seize, and Loc-Tite, and Oil.
I recommend putting a good quality oil and friction modifier in at first.
(I used Valvoline Gear Oil)
Then after 500 miles dump it, and put a Great Oil in it with modifier.
(I like AMS Oil Severe Gear)
But that choice is yours.
There is a proper break in procedure to do for that 500 miles.
Damn it was hard to not just go see what effect they had, but I bit my lip and did it.
The gasket is like a no need but it comes with all the kits.
I would highly suggest the Ford Racing A gear set though.
Here there is a big advantage using the Ford Racing gear set. It is made for Ford using extremely tight tolerances. The Ford pinion will be marked with a number. Ours for instance is marked -6 (minus 6). This is our pinion bearing shim size.
I did a full step by step writeup on FordMuscle.com but you need to be a paying member to access it. Largest writeup in their history for now.
I sooo wanted to post it here but I cannot.
