RedFire07GT
11sec N/A 3V
so they do not come with these centering rings?
No dave, The racestars do come with Centric Rings. Im having the same issue with my JEGS for the rear.
Hey come with them based on who you ordered them from, I ordered from BBR and they came with the rings, as do brenspeed.
problem is the washers are offset, best way to get them on with no issues is always run the lug in at the lowest point, then spin the wheel and repeat til all five are snugged, use a deepwell socket and push it all the way in so that the washer is lined up in its groove. it does take an extra min to do so but its not as hard as your making it out to be, if you have bent studs its because you did it wrong, if the washer isn't in the proper location then it will tighten down all wrong
just to everyone getting new racestars the only recomemdetion ill give you is to chase the threads on the lug nuts before you install them.
why so?
Great info...took me an hour to put on ONE rear ...
I was approached by a fellow racer this past weekend at Cecil, asking did I have any problems putting on my rims?
YES...
^^^^it really shouldn't. I have had mine on since feb and I DD my car with no issues. The threads are more so what to prepare yourself for rather then to bitch about the wheels. They are awesome for the money and I have no regrets that's for sure!!!!
That was me!!
