Liftedbronco
Shredder
So I need to get these out. I see the end of the stud looks like an allen key. Whats the actual name for a tool thats a inside out allen key? lol.
Double nutting is probably a better solution. You put two nuts tighten one against the other and turn out with the inside nut. You could even do both double nut with a box end wrench and put the 3/16 socket on the end you want to spread the forces out as much as possible. Oh and use PB Blaster on the threads and let it soak it does help.
Used a socket here. I think it was 5.5mm. I kept as many as I could in but didn't have a problem with the ones that had to come out.
