The 2 top bolts are going to be tough to get at.After I removed the battery and tray I was able to get to it alot easier then under the car spent a good 30 minutes trying to find it under the car and got it out in under 5 from the top.
Thanks for the information! Probably have a lot more questions since tomorrow I pull the tranmission out! Got everything ready to go for tomorrow.
Are you removing it on jackstands?
originally posted by travelers:
I just used a long extention when I installed my headers.
I did the same thing only to find out the trans was still to high to get out from under the vehicle once I got it removed. I had to wrestle the trans off/on the trans jack while still under the vehicle by myself without damaging anything. What a bitch!!Hehe---I did. Got the car as high as I could on all four corners with four jack stands.
I used a swivel 13 mm I believe it was on about a 3' long extension to get the top bolts. Was fairly easy that way.
