*JZ*
http://www.blowbyracing.com/rexdca.html
Featuring a water-resistant, hard anodized, rugged aluminum housing for your extreme adventures. The Replay XD1080 is the smallest and lightest full HD action-camera on the market.
Simple, two-button ON/OFF and Start/Stop make the Replay XD1080 camera easy to operate. Simply turn it ON and Press Record to Start. The built-in LED & Vibration Feedback tell you that you’re ready to go.
It’s really that simple.
Mounting
Replay XD1080 can be mounted practically anywhere due to its small form-factor and all-round shape. There are two mounts included with each system to get you recording in no-time.
HeimLock Mount (Swivel/Tilt): Features spherical adjustment with an eccentric cam-lock for a rock solid mount. Over 1,036,800 Mounting Positions with 360º lens rotation, 360º camera rotation, and 8º of tilt, not including the unlimited areas you can mount 1 of 4 included SnapTray VHB bases.
Included are 2 Flat SnapTrays and 2 Curved SnapTrays with 3M® VHB adhesive to securely mount to smooth surfaces: metal, paint, powdercoat, LSE & HSE plastic. 3M® VHB adhesive ensures secure mounting and removal without harming your surface.
LowBoy Mount (Fixed): Lowest profile mount, offers 360º lens rotation. Designed to be low and out-of-the-way. Compatible with our SnapTray VHB bases.
HardCore (Billet): Optional billet-aluminum pro mounts are available for the most demanding action and motorsport applications. Tubular, Flat, Curved, Tripod, Universal, & Specialty mounts are available.
HDMI
Replay XD1080 is the first to stream full 1080 HD through the built-in HDMI out connector. You can record and stream your video simultaneously or just stream your video straight to an external HD recorder.
Compatible with: Live streaming via HDMI microwave, WiFi, 4G Transmitters & HDMI In HD Recording Decks.
Replay XD1080 features class leading optics. Never before has an action-camera featured such a high quality lens. With its custom designed wide angle 135º, f3.1 lens, and anti-glare coating, this lens is finely-tuned to match the 5MP CMOS sensor for better clarity, accurate color, and minimal image distortion.
Replay XD1080 also features a removable front lens bezel to accept our ProLens 37MM Adapter Lens & Filter Kit.
Internal Audio:
Along with everything else, we spend a lot of time obsessing over audio. We’ve accumulated thousands of hours developing, engineering, and testing the right combination of acoustic materials and microphones to suppress windnoise yet still capture realistic audio.
External Audio*
For the extra critical audio situation we have built in an External Audio option to connect high quality Lav Mics,Ext. Audio sources, or other In-car Radio Communication through a standard 3.5mm Mini-jack adapter.
*External Audio Line-In available via Replay XD1080 HW Adapter. Available Soon
1080P@30fps, 960P@30fps, 720P@60fps, 720@30fps, Photo@1, 5, 10 & 15 sec, Internal Audio, External Audio, Rec, Stop, Play, Skip Forward, Skip Reverse, Clip File, Live Video Out. Wow.
That’s a lot of modes. Don’t worry we made it easy.
Set the Mode once and it sticks. There’s no need to count button presses or reset your settings each time you use the Replay XD1080.
If you forgot what mode you were in or what they mean, just look inside the rear cover for a simple reminder.
Replay XD1080 was designed with size and weight in mind. HD cameras don’t need to be big and bulky to capture great video. Replay XD1080 utilizes the perfect blend of size, shape, and style.
Replay XD1080 features a high-strength aerospace aluminum body – Mil-Spec hard-anodized for extreme durability to withstand the inherint demands of video-actionography.
Weather-resistance is a must when dealing with action-cameras, so Replay XD1080 features a double o-ring sealed lens bezel, rear cap, and top push buttons to keep out those harsh elements.
Smaller than a gopro
Less vibration
Less wind and background noise
This is such an awesome video camera!!!!
