S197 18x10 w/305s
NEMustang
Mad Motorsports Products
North Reading, MA
I have been searching the various threads for about two weeks to find the answer...no luck so I am asking here.
The car is a 2007 GT/CS. I am attempting to fit 18x10 all around for track only. I know that Roush and others fit an 18x10 all around...usually with an offset from +40mm to +45mm. I am attempting to determine if Toyo RA1 305/35/18 will fit and if so, what is that appropriate offsets (maybe different front and rear).
Limitations:
  1. Do not want a staggered solution
  2. No SLA or otherwise modifed suspensions. However, I am looking at the Ground Control/Koni setup which does provide an extra +5mm clearance.
  3. Tires tread must not extend past fender vertical line (Track sanctioning body restriction)
  4. No body changes (flares)
I am pretty certain that a +40mm to +45mm offset will work in the rear. The challenge is the proper offset in the front. I do have confirmation from someone running 295s in the Front with 18x10 +38mm offset. Since camber for the track is -2 or more (really...less...more negative!), the tread is within the front fender.
So, my challenge is to find someone running 305 or greater, all around.
Thanks in advance for any tech provided.
Chris B.
PA
I know other people here and on other Mustang forums had issues in the past with the tires rubbing if they went wider than 285's on all 4 corners. You probably can do 305's in the rear, but up front it may cause some issues. The only people I know that have 305's and 315's up front have the Griggs suspension.
