Saleen S-Style 7 Spoke Question
jashton
Does anybody know whether or not the 20x10 Saleen Reps will fit up front with out the use of spacers? I was going to go 20x10 all around if possible without clearance issues and run a 275 tire up front with 295's out back. Offset is +45 I don't see there being much of an issue but would rather not have to put on a spacer.
I calculated 20mm less inner clearance then the 9" wheel and the wheel will extend out 6mm further toward the fender. My ultimate question is if they will clear the stock brakes or not with the hub being pushed 7mm in further.
-Jeff
Dread53
Woodland Park, CO - 9000 ft!
I was talking with a SCOA member from Australia last weekend who uses 20 x 10's all the way around on his hillclimb Saleen in Aussie. Not sure what size tires, but no fitment issues.
